Go Back   TinyRC.com > 1/43 and Smaller > Epoch RC1/43 Indoor Racer > Epoch RC1/43
Old 10-29-2003, 08:53 PM
bjv5 bjv5 is offline
Problem with 4cell
I am having problems with my spec2 when I added the 4th cell. I am charging it with the apex ac optional charger with the stock charging jack. The problem started 3-4 runs after running with the 4th cell (extremely fast). I then started to see a decrease in speed and later on the car would act as if it had only 3cells to power it. So I was wounder if I could find out what the problem is.
Old 11-03-2003, 01:14 PM
burgan burgan is offline
this is probably a "natural" thing..
particularly if you added a fourth cell to three cells that you already had run for a while.
the voltage of the 4 cells will start to drop after a few minutes so it will start to run like a 3 cell. under the same conditions the 3 cell would run even slower.
also, when you run 4 cells you are using more current so the battery's voltage will sag more quickly.
Old 11-03-2003, 06:26 PM
thanx
Old 08-09-2004, 10:02 PM
jasonip jasonip is offline
Actually if you look at the discharge charateristic of NiMH batt., you will know more why it slow down and act like a 3cell. When it is fully charged, each cell will around 1.4v (total 4cell ~5.7v) which has a higher top volt. and thus higher top speed.
After a while run each cell drops to a level ~1.1v which act like a fully charged 3cell(~4.3v).
You can refer to my another article for further information:
http://www.tinyrc.com/forums/showthr...threadid=19895
A problem with my mini-x RX and TX Smurf Mini-X 0 12-02-2003 10:32 PM
Serious Problem... Pocket_Rocket XMODS Parts and Hop-Ups 10 11-08-2003 04:02 PM
sputtering problem with my new zap... Cool Dad ZipZaps 12 06-20-2003 11:05 PM
Dogbones popping out? No problem. bluemax_1 Mini-X 3 04-01-2003 10:39 PM
Transmitter problem (picture included) ryanhook Bit Char-G / MicroSizers 11 12-26-2002 08:29 PM
