Old 04-07-2004, 12:16 AM
JrC JrC is offline
SE - Lights
Does anyone know of a way to make the headlights and the tail lights stay on the entire time?
JrC
Old 04-07-2004, 09:31 AM
codesuidae's Avatar
codesuidae codesuidae is offline
Send a message via AIM to codesuidae
The red and black wires in the light connector are power and ground, the other two indicated forward and backward. If you were to connect those two wires directly to the red wire, it might keep the LEDs on all the time (it depends on how the circuit is set up).
You could also just cut out the little circuit board and wire the LEDs directly to the red and black wires. You probably can't get them to run in series because of the low voltage, so you'll have to put them all in parallel and use a resistor of about 40 or so ohms in series with them (thats one resistor connected to power, then four leds from the resistor to ground).
Old 04-07-2004, 12:08 PM
JrC JrC is offline
Thanks for the info.
Am I the Only one interested in this? I see a big lack of discussion and Mods for the new SE which are so much better then the old ones.
JrC
Old 04-07-2004, 03:00 PM
codesuidae's Avatar
There is a reasonable amount of interest in the SE, there just aren't many users involved in SE mods active on this board.
The blue board (the name of which has been deemed unmentionable by TPTB) has a more active ZZ forum.
Command Logic Lights MODS drewdown84 XMODS Mods and Projects 4 07-30-2007 01:33 PM
glow lights on car SkylineEvo XMODS Mods and Projects 0 11-12-2003 12:48 AM
running lights from car battery esp rocker Bit Char-G / MicroSizers 4 06-24-2003 01:23 AM
putting lights in my car xatu Miscellaneous Discussion 12 06-04-2003 12:06 PM
Lights and Bit Char-G DigitalAce7 Bit Char-G / MicroSizers 1 11-08-2002 03:45 PM
