06-26-2003, 11:50 PM
not so bright
zz cars into boats...
I was down at a creek behind my house and i had an idea of a zip car conversion into a boat...but the thing is there are many ways to do this and i want your opinions and ideas. My idea was get a styrofoam box that could hold the car (palm size), then get some thin wires bend it over the back of the half box holding the zip with a propelor on one end of the wire. The thing is i havent put too much time into this so i wouldnt really know how to put the gears a spinnin. Remove back wheel and make a custom one for this job...thanks
deace out
06-26-2003, 11:57 PM
It won't work. The water will get into the mechanics and mess it up. Other people have had this idea and failed at it. Sorry, but it is a hard thing to master.
06-27-2003, 12:00 AM
not so bright
maybe u get wrong idea the thing is fully *well not fully* protected the only thing exposed is the top of the car and the propelor would be totally in water so it wouldnt splash up
deace out
06-27-2003, 12:07 AM
My bad....But I would like to see the steering.....that would be tight!!!
06-27-2003, 12:09 AM
not so bright
i guess that could be done with some kinda connection to a fin behind the motor causing it to turn
deace out
06-27-2003, 02:23 AM
i think that making kinda of like a hovercraft but without the hover, cause that would require alot more power and toque, but like have a propeller and the eletromagnets turn a little rudder to direct the air, or if you really have you heart set on a boat, you could do anyhting like wire in extra motor or two or just use the existing electromagnets to drive a fin on the underside of the boat through a shaft or something.
06-27-2003, 01:10 PM
not so bright
thanks cool dad
deace out
12-22-2003, 02:26 PM
D1 Grand Prix
just get a boat from like hot wheels or somthing, get two spare motors and solder wires to and from the battery and the engines. get some electrical tape to protect the motors from the water and heat up a nail and melt a clean hole (if the boat is plastic). Peace
12-23-2003, 12:55 AM
Weird, I was thinking of this earlier tonight. Welp, I know a BIT Racer can live through water. Tested it tonight..wouldn't have a control method..but it'd go.
I wish my Land Rover was a rotary
12-25-2003, 01:24 PM
D1 Grand Prix
maybe som how set up a second motor to turn a steering thing? like the things that sail boats use to steer. i have a fake clone "stunt vehicle" and it comes with two motors to work with so if u hook up the second motor to be a steering mechanism or somthing...
R u calling me a welp??? im only trying to help buddy.
12-27-2003, 12:43 AM
It's Really Fast!
You're looking at this thing like you're Rube Golberg (did I spell that right?). What you need is another gear riding on the axle gear, then runs it up or down to a prop w/ a propeller. This would allow for "driving" straight into water. Then a rudder could be hooked up to the steering. It would work well with a ZZ SE. You run a second servo in parallel, then hook it up in the back on a rudder with a hinge. there ya go! Make a hull, waterproof electronics (shrink wrap), and you're set. The only problem is charging. For that, you'd have to make a wire that would "plug" into the controller. Another one of my rants, but I think that sums it up. Also, it would go into water like this car...
http://www.watercar.com/video.html
Project Bad Brushless:
Just say no to giant sigs.
12-27-2003, 02:21 PM
Confirmed: Lost In Fog
ya...they have those at the walmart here in my town....i am going to get one...(once i get rechargable bats and level 2 motors for my xmod...).....
-Andres
02-26-2004, 08:48 PM
walmart, micro boats 14.99, 50 ft range, mde by the people who make monster trucks, use zz motors and standard bats, two motors, one stops or reverses to trun it.
I feel The Need, the need for speed! -Top Gun
02-26-2004, 09:04 PM
It's Really Fast!
Yeah, but I like the challenge of making my own boat.
