02-03-2004, 10:20 PM
Have a hosed electronics board ?
I am looking to buy your hosed electronics board from your xmod.
I want to do some practice removeing/soldering in fets.
hopefully somone has a messed up board I can get cheap :-)
02-05-2004, 01:22 AM
pcb? RIGHT HERE! how much you want for it? on my board there is something wrong with the range, maybe its hte antenna or something but i dunno ill sell it to ya!
02-05-2004, 11:25 AM
i dunno say 10 bux should cover shipping and a few bux for your trouble. ?
02-05-2004, 12:30 PM
Got Brains?
um......
dude, you can go to RS and buy some blank circuitboard or bread-board to practice your soldering and that junk is like 50 cents.
This is your brain.....
02-05-2004, 04:46 PM
Check your L2 inductor, near the command logic port.
02-05-2004, 08:54 PM
TinyRC XModder
Re: um......
I think the whole point is so he can practice on the real thing.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
02-06-2004, 10:18 AM
if you're just starting to solder find a broken radio and practicing removing through mount resistors. then when you get good at that go for the surface moutnt stuff like resistors and transistors. mosfets are surface mount so you better be good at soldering. or you could go buy one from the dollar store or something. im surrounded by them up here.
02-06-2004, 04:29 PM
soldering
regular <through hole > components I dont have any problems with but I have not messed around with surface mounted components.
02-07-2004, 12:08 AM
Still need one?
I can sell you mine when I get a new one.
Huh?
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
02-07-2004, 10:22 AM
Replace this.
02-07-2004, 12:08 PM
Even though it looks like this...
G35 rolling chassis
H2 rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
02-07-2004, 03:07 PM
My post was mostly directed to wasuri, who is having range problems which usually indicates a bad L2 inductor.
02-07-2004, 04:00 PM
Just because it doesn't look fried, doesn't necessarily mean that it is ok. The only way to know for sure is to measure it. Use a multimeter with an Ω check, or a continuity checker. Small inductors generally measure close to 0Ω (basically a short circuit). If it measures more than say 1Ω, it is bad. Both L1 and L2 measured as shorts (0.1Ω) on my board.
02-07-2004, 04:08 PM
Ok, I learn a lot on this board.
would removing both L1 and L2 make it go further?
Does RS have the parts to replace the L1 and L2?
thanks
G35 rolling chassis
H2 rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
02-07-2004, 04:29 PM
TinyRC XModder
thanks
No, someone tried that, and it didn't work.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
