Old 01-15-2004, 08:49 PM
RC 2NR RC 2NR is offline
TinyRC XModder
Talking A few quick mods for ya'll
I 've got a few easy mods that I've done to my XMod, I jusr thought I'd share.
BTW, if anyone can think of anymore, post away.
-If you want to make your XMod quieter, it's easy: all you have to do is take apart the differential and put a light grease on all the gears (you can also put some thicker grease for an LSD effect).
-For a cheap alternative to metal bearings upgrade all you have to do is take out all the nylon bearings and lubricate them with some fine powedered graphite (found @ your local hardware or hobby shop). For directions on taking out the bearings, use the metal bearing upgrade directions: http://support.radioshack.com/suppor...oc72/72042.pdf
-It's a good idea to put a layer of hot glue on the battery terminals to prevent them from accidently shorting out on the motor's heat sink.
-To keep your motor a little cooler try polishing your heat sink (if you have the stage 2 upgrade) with a little rubbing alcahol and a dremel with the polishing attachment.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 01-15-2004, 09:59 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
i think toothpaste would be a better polishing agent because someone said it contains tiny amounts of silica, a polishing agent
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 01-16-2004, 06:23 PM
jaubery jaubery is offline
I polished mine with brasso. Looks like chrome now. It doesn't make your motor run cooler though.
Most Cost Effective Mods rggtm XMODS Parts and Hop-Ups 20 07-01-2004 12:12 AM
Mods For New-bes(and advanced) xmodsman Bit Char-G Mods and Projects 5 01-31-2004 08:18 AM
My new mods and traction problems. Procrastinator Bit Char-G / MicroSizers 17 05-24-2003 08:47 PM
step by step how to for mods Twistid ZipZaps 2 12-27-2002 03:03 PM
Anyone Found any "Do It Yourself" Mods for ZipZaps? hawks10 Bit Char-G / MicroSizers 6 09-25-2002 11:41 AM
