Old 12-23-2003, 12:10 PM
shuboyje shuboyje is offline
Dual Cell
Simple question. Can you Dual cell an SE, and if so what voltage can they handle. All this talk about FET moding has me thinking their may be a FET used as a voltage regulator, in which case a dual cell would be useless
Old 12-23-2003, 01:24 PM
charliebrown's Avatar
Welcome to the forums.
First off, The SE already has a dual cell battery inside. You will need another SE battery, then make a quad cell. As for the FET mods, no they aren't voltage regulators. In fact, they allow MORE voltage to go to the motor, making the car faster.
Chuckster...
Old 12-24-2003, 02:11 AM
Ok, so it can handle 4.8v? I've got a cool schematic drawn up for a 9 mode power supply using two single pole triple throw switches. It would allow each battery to run individually(define battery as 2.4v power source), both in series, or both in parallel. Sound cool?
Old 12-25-2003, 07:35 PM
Yeah, it can take 4.8 volts..maybe even 6...maybe...
And, yes it sounds very cool......switching from parallel to series..... let us know how the project comes along!
Chuckster...
Old 12-26-2003, 08:44 PM
viperdout's Avatar
It's Really Fast!
From what I've read, it has a separate voltage regulator, and a dual cell is useless, unless you have FETs.
which dual cell should i do, laymans, external, internal etc eman1 Bit Char-G / MicroSizers 11 09-02-2003 07:42 PM
Laymans dual cell vs. traditional dual cell Zephyranthes Bit Char-G Mods and Projects 6 02-18-2003 06:12 PM
Dual cell mod ( will 2 - 50 mah's achieve + speed?) Suntzu28 ZipZaps 7 01-11-2003 09:57 AM
Dual cell mod and discharge problem (cell reversal). kenny_dilger Bit Char-G / MicroSizers 1 12-17-2002 10:23 PM
