12-20-2003, 09:12 PM
Off-Road XMOD with more speed!
Hey guys, I just figured out a great way to make the XMODS run on thick carpet, rocks, almost anything, and have more speed! If you buy the tire upgrade kit, and just overlap the tires on the wheels, the clearance is huge! My clearance is 3/8 inch, and because the wheel is larger, it goes way faster, too.
My setup (from inside to outside) is: hard slick, hard tread, soft tread (inside out for better grip on the hard tread), and soft slick. I couldn't use my stock slicks because they are so worn out.
This does strech ou the tires alot, and I'm not sure they'll ever go back to normal, but I think it's worth it to be able to drive on anything.
12-20-2003, 09:26 PM
XMOD AUDI TT (my wish)
good idea does it look good too? or is it like weird looking.... and arent the wheels wobbley? (sp?)
12-20-2003, 09:27 PM
My question would be if they rub on the wheel wells or chassis when you turn?
12-20-2003, 09:40 PM
The body won't fit on the chassis with the huge tires, but they don't rub on the chassis if I turn the ST. Range down a little. I do get huge grip though, so when I turn sharply, it flips alot. The wheels don't wobble at all, because the momentum of the outside of the wheel keeps it in line. I should get some different rims, though, because stock skylines look horrible with 1/4 inch tires. I'm thinking about getting a Hummer H2 body to put on it, i just saw a good one at Target today.
My Tiny R/C:
XMODS Yellow Skyline GT-R
AWD
Jumbo Tires
Stock everything else
12-20-2003, 09:46 PM
do it do it do it do it
and dont forget the pics when ur done :-)
12-20-2003, 09:52 PM
Yes, I would like to see this.....DO IT!
12-20-2003, 09:53 PM
I'm getting the body tomorrow, I think I'll paint it maroon, maybe. I'll post pictures as soon as I get a digital camera. I also want to put a light rack on the top or the grille.
My Tiny R/C:
AWD
Jumbo Tires
12-21-2003, 12:50 AM
("\(0.o)/") Rawr!
Xmod Parts Help
12-21-2003, 08:48 AM
Can anyone find a way to make any of these???? Instead of monster trucks , SUV's and the like. They look cooler.
12-21-2003, 08:55 AM
I've seen a model but I have no idea on how to raise my ride height. Martlet21, can you post a pic of your car. I'm thinking
The perfect off-road setup so far:
That tire mod
stock bushings
Skidplate
and maybe a plastic covering for the top of the chassis (between the chassis and the body).
12-21-2003, 11:10 AM
There's no way my tire mod will be able to accommodate a WRX body, because the tires are just too large. It might work if you just overlapped the hard slicks and hard treads, but then you still wouldn't get enough clearance to run off-road. Also, for real off-road, you'd nee to seal up the front and back cavities where the axles are. If real dirt gets in there, you'll need to clean extensively after each run.
My Tiny R/C:
AWD
Jumbo Tires
12-21-2003, 05:54 PM
That is one of the reasons why i suggested leaving the stock bushings. Light dremmeling can also fix the wheel well problem. Can your mod run on hard packed dirt? No rocks, just compacted dirt.
Plus the ride-height if the body can also be changed. Raised in this case.
I have a WRX body coming, can you post a pic so that I can see what I will have to work with. I cannot do it myself becuz I only have the stock tires. more coming with AWD etc.
12-21-2003, 07:44 PM
like my dog??
i have tires from some other thing that i found around the house, but they are perfect!!  you can see them in the pics\/. the body fits but the tires are right up to it. the tires are a little harder, so they do not run so good on wood floor, but they rock one carpet!!  well my diff is messed up(also the peice that conects it to the dogbone, any help please!!?) so i can not tell you how fast or what it is, but here are the pics...
--Chris
Aka...aero528
12-21-2003, 07:46 PM
like my dog??
btw the tires did not fit before, but with the stock tires underneith they fit VERY snugley...
--Chris
Aka...aero528
like my dog??
two more...
--Chris
Aka...aero528
