Old 10-03-2002, 10:10 PM
go_zz_go's Avatar
go_zz_go go_zz_go is offline
more power!!
not charging
after all this battery changeing my zz would not charge after messing with and almost throwing across the room i realized the metal tabs are not positioned right. check the bottom and see if you see two silver tabs on each side the ones closer to the rear are the ones that make contact just thought i would worn you before you get pretty upset with your zz and call it a few choice words
Old 10-03-2002, 10:15 PM
ax0n
after having my battery out a few times and having to reposition them about 20 times whenever I wanted the battery back in, I finally used a dab of LocTite QuickTite Cyanoacrylate Gel to hold 'em in. They ain't goin NOWHERE. Be sure to let it dry before putting teh battery back in.
Also, as superglue hardens, the fumes tend to collect on any surfaces that have body oils or moisture, leaving a nasty white crusty residue, so be sure to leave the circuitboard out of the way too, and then clean the contacts (especially where it meets the battery, and where it meets the charger) with alcohol-soaked cotton swabs and you should be fine.
Old 10-03-2002, 10:18 PM
go_zz_go's Avatar
more power!!
dang i was just about to ask if i should use a special glue for this thanks for reading my mind
My car stopped Charging! moxman Bit Char-G / MicroSizers 9 01-12-2007 11:20 PM
Charging Dual Cells... syncronized Bit Char-G Mods and Projects 2 04-25-2003 06:10 PM
electrical question about charging..resistor values..limiting current.etc Clint Bit Char-G / MicroSizers 17 03-07-2003 02:49 PM
