Old 09-21-2002, 02:31 PM
BaY oN AiM's Avatar
BaY oN AiM BaY oN AiM is offline
sLaNteD ViSiOnS
Send a message via AIM to BaY oN AiM
Microsizers Drift Axles
umm...do i put tires on the drift axles???
they have no grip at all no matter wat surface i run on....
every time i turn it spins out....
"Nobody is perfect until you fall in love with them."
- Me
OH YEAH, GO KILL A BIRD!
Old 09-21-2002, 04:26 PM
tinyrc's Avatar
tinyrc tinyrc is offline
Nope, that is how they are supposed to be; try it on a canvas-like surface.
Old 09-21-2002, 04:41 PM
BaY oN AiM's Avatar
sLaNteD ViSiOnS
hmm... should i just put plastic rims in the front then.......?
- Me
Old 09-21-2002, 04:56 PM
tinyrc's Avatar
Have you tried hard tires up front? If that doesn't work, then yes, plastic might give you better results.
Old 09-21-2002, 06:35 PM
lilaznboi
i just use my drift axle for the carpet u get good grip and go about the same speed as tile
Old 09-27-2002, 12:10 AM
d00kie's Avatar
d00kie d00kie is offline
It's super useless!
Its too bad these suckers won't come any close to a perfect drift.
Man, i was really looking forward to trying to drift the cars. Maybe I'll figure out a way, or one of you guys.
Old 09-27-2002, 01:15 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
the reason u cant, is because the damn front tires...they wobble left and right too much, and when u try to turn realy fast, they just stay planted in one direction, or in a random direction really..
and donuts ahoy!
i spent a couple hours with that damn axle, i tried tire combinations, weight distribution, etc...the only thing i havent tried is increasing the front camber, and that will take some drilling/sanding....and i didnt wanna do that until i find another chassis cover to mess with
Old 09-28-2002, 02:48 PM
323iT's Avatar
323iT 323iT is offline
its good for 1.0 motor. anything faster its not possible to turn
Old 09-28-2002, 02:49 PM
323iT's Avatar
with the right setup. its possible to drift. its easier if you have a boost machine
Old 09-29-2002, 12:06 PM
cowfish_29's Avatar
yellow fish forever!
also, try not using the drift axle at all...use the medium and hard bit racer tires on hardwood floors..i get some good drifing with that...im gonna go drive now...
Drift Guide 2fast4u XMODS 30 01-20-2007 06:27 PM
Stock ZZ drifting? Elpizo ZipZaps 6 11-06-2006 08:04 PM
Microsizers Pro vs Microsizers ilkera Bit Char-G / MicroSizers 5 10-30-2003 10:46 PM
TinyRC Drift Axles Yaksha Bit Char-G / MicroSizers 1 11-23-2002 11:53 PM
