Old 08-03-2003, 10:02 PM
eetoi's Avatar
eetoi eetoi is offline
Hardcore Otaku
Stock bit battery charger
I just now read here (somewhere) That 45 minutes can be attained from the stock bit battery. I have a rayovac 1-hour charger for nimh and nicd AA and AAA batteries. I want to charge my bit battery with this, but I don't know at what rate it charges at and even if it is safe. When I pull out freshly charged 1850 Mah nimh's, they are hot enough to burn my fingers. Has anyone tried to charge their bit battery with one of these chargers? Oh yeah, it's model number is PS4 (I think).
Old 08-03-2003, 10:26 PM
eman1 eman1 is offline
custom title
Send a message via AIM to eman1
any batterys you charge should be warm when done. If they are hot, your charging too much or too fast.
current parts:
auto modellista
4.2 pro
perfection 200mah battery
Pullback wheel mod
Plantraco desktop rover for sale
email me at eman54@optonline.net if you want it
Old 08-03-2003, 10:44 PM
boho's Avatar
boho boho is offline
Camera springs
Nimh charge slightly different. They hold heat internally where nicads discharge the heat externally, so if a nimh is warm on the outside, it probably means that the inside is baking itself to death.
Old 08-03-2003, 10:46 PM
eetoi's Avatar
Hardcore Otaku
Well, I can't control the charging rate of this charger, and this was done with a charger and it's recommended type of batteries. Same brand too.
Old 08-03-2003, 11:48 PM
SkyLiNEz MK-V
then why not take it off the charger after like a half hour? then you have a full charge and you wont have to worry about having to buy new batteries, or melting your PCB
Old 08-04-2003, 05:41 PM
eetoi's Avatar
Hardcore Otaku
AAhhh. Nevermind, disregard this thread. I tried it, but then I forgot that the charger can tell what it is charging. Instead of frying the battery, the charger light just kept blinking and didn't charge it. So much for using what you already have. I guess it's either the digital multimeter or the high-end peak charger
Old 08-05-2003, 10:51 AM
Namuna's Avatar
Namuna Namuna is offline
That 1-hour Rayovac puts out something like 1.5Amp or 1.8Amp (I believe. That's a good bit of juice, but if properly monitored should be able to handle the Bit Battery.
...UNLESS, that Rayovac can only charge batteries in pairs? If so, then the circuitry is looking for a 2.4v pair of batts and is cutting off when not detecting it.
Old 08-05-2003, 11:19 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
why do you need 45min runtimes? i get bored or distracted after about 10mins
Old 08-07-2003, 05:33 PM
eetoi's Avatar
Hardcore Otaku
WOW, 1.5 to 1.8 amps????? That's sounds scary if I were to use it on one of those 1/3AAA cells. BTW, the charger charges each cell independently, no dual cell setups needed. And yes, I get bored after 10 minutes too. Actually, with only a 1.6 motor I get bored after 2 minutes. I think I'm going to scrape my resources together and go "full size" rc-ing again. I just don't get any thrills from bits, esp. with no one to race When I get behind the wheel of my rustler after not driving it for a while, or after getting a substantial speed hop up, I feel like I'm the controller of a real fire-breather, and it's electric!
easy battery charger chameleon Bit Char-G / MicroSizers 6 07-11-2004 06:38 PM
V and I for dual battery charger? ejaf ZipZaps 10 11-22-2002 08:29 PM
Standalone AC/DC Charger and 3AAA Battery Combo tylude ZipZaps 0 11-19-2002 02:48 AM
