06-30-2003, 03:26 AM
bearings
Anybody knows about the bearing's thicknes?
Thank you.
06-30-2003, 04:48 PM
I shall call him Mini-Me
which bearing's r u talking about?
future car: white 1966 Pontiac GTO
06-30-2003, 08:44 PM
Re: bearings
Thank you.
All bearings that mini x need. 8x12 and 3x6. Are those have differen thickness?
Thank you.
07-01-2003, 02:29 PM
the 8x12s r ±.137 and which ones r the 3x6s?
07-01-2003, 09:35 PM
Do you mean 1.37milimeters?
The 8x12s are for the diff. bearings and the 3x6s are for the wheels bearings. Correct me if I'm wrong.
Thank you.
07-02-2003, 10:30 AM
no its .137 inchs or 3.4798mm and i lost my wrench for the wheels so i cant find out the size of the 3x6s.
07-02-2003, 09:12 PM
same thicknes w/ mtr shaft mount?
Let's make it simple: is the 3x6 wheel bearings have a same thickness with motor shaft mount bearing? Anybody know?
TY
07-03-2003, 12:23 AM
The 3X6s are either 2.0 or 2.5 mm. I don't remember for sure but I think it is 2.5. They are the same width as the 3X6s in a mini-z.
The 8X12s are probably 3.5mm. Since these are Japanese cars everything is metric.
07-03-2003, 12:49 AM
Yup, the diameter is the same as mini z wheel bearings, but the center hole is different.
It's hard to get ones here.
07-03-2003, 01:01 AM
07-03-2003, 01:10 AM
mini-eX-Driver
you should get dynamite redseal bearings. i got them all around, the diff and wheel bearrings (10 total). they work better than any bearing i have tried, they never need to be cleaned cause they are teflon sealed and they are pretty :P oh oh and they have a perfect fit too. i got them at my local hobby shop (CycleArt)
07-03-2003, 01:32 AM
You luckily lived at SJ.
In Indonesia it was hard to get one of them.
07-03-2003, 01:38 AM
I was actually referring to the mini-z axle bearings. Mini-zs come with 4 wheel bearings - 2X6 and 3 axle bearings - 3X6. The mini-x bearings are the same exact size as the mini-z axle bearings - width, outside, and inside.
07-03-2003, 01:51 AM
YES!
THat was bearings for rear axle at motor pod and one of rear wheel.
Thank you very much!
