04-21-2003, 01:32 PM
MASTA POOOOOOOOOOOOOOTANG
Bunta Help
bunta on ur website about the vertical dual cell it says to solder off the whole pcb then re solder it back on.well i did it and it works great!! but the problem is i havent soldered the steering wires because i noticed there were 2 wires for each front wheel so i dont kno which wire to put where. i kno 1 wire from the left wheel and 1 wire from the right wheel go on the spot right next to the positive wire. then the other 2 i dont kno which to solder on. can u show a diagram or tell how u know which wire goes where?
MICROSIZER PRO:  2 SPEEDS, 1.3 NIMH, 49 MHZ, SKYLINE R34 GTR custom paint, pull back wheels, blue head lights
MICROSIZER SPORT:  1.3 nimh, rest is stock
panther=  2.4 nicd, rest is stock
MEGATOYS rc:  rest is stock
bitchar-g:  rest is stock
04-21-2003, 01:54 PM
ok this is from memory but the ones with the white crap on them go to (+) and the ones without the white crap go to l and r.
04-21-2003, 04:29 PM
Hi peeps,,
calsonic racer,, When you disconnected the old PCB,, you noticed that 2 of the steering wires went to the same spot as the + lead from the charging contacts,, (I think you got this one correct). The other 2 steering wires are from the left coil and the right coil.
Now with most clones I've dealt with the little letter on the PCB that mark "L" and "R" go to the OPPOSITE steering wire. In your case the wire from the left steering coil goes to the "R" terminal on the PCB, and the wire from the right steering coil goes to the "L" terminal on the PCB.
I hope this helps,,
-Bunta
Custom Mods R us
