Old 04-09-2003, 05:15 PM
Jr08bll Jr08bll is offline
Call me Darth Balls
Send a message via AIM to Jr08bll
Exclamation Found Steering Problem You Should All Look At This!!!
As you guys have probably noticed now I've had steering problems with my r/c. The two most common things you said were "take it apart" or "all of them can't steer right". So at a closer examination of my R/c revealed something. I flipped over my r/c and looked at it with a big magnifying glass and to my surprise found MICROSCOPIC metal pieces smaller than a flea. And I noticed they sat on one side of the front pulling the steering magnet towards them therfore making my car drive only to the left. After several minutes trying to remove them with some tweezers I found my car could properly turn as if it had just came out of the box. I hope this helps those of you who are having a similar problem!
Old 04-10-2003, 12:19 PM
SlowbutCourious's Avatar
State Property
it's amazin how much little magnetic stuff is realy on the ground!..and we would have never known this if we never bought BITS..is there a mill around where u live?..
Old 04-10-2003, 03:29 PM
Call me Darth Balls
I KNOW AMAZING ISN'T IT! There are a few mills about 10 mi. from my house and my dad works at one of them but its a paper mill
Old 04-10-2003, 03:38 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
ive posted this a million times.
glue a magnet to the tip of your antenna. you will always have something to suck the metal off(much better than spending all day using tweezers).
no it does not effect range at all in any way
Old 04-10-2003, 03:40 PM
Call me Darth Balls
Or couldn't I just glue a tiny magnet to a pair of tweezers?
Old 04-10-2003, 03:44 PM
hogjowlz's Avatar
you could glue a magnet to anything but you always have a controller in your hand when running your bits so why not put the magnet there so you dont have to carry tweezers around?
Old 04-10-2003, 03:51 PM
xatu's Avatar
xatu xatu is offline
they say im slooooow eh?
You could also put a small piece of tape over the bottom of the car, and take it off when there is lots on there.
Old 04-10-2003, 03:54 PM
Call me Darth Balls
That might work. But imagine for those of you with rare earth magnets that must be a B!TCH trying to get off those little shavings
Old 04-10-2003, 03:57 PM
hogjowlz's Avatar
no. you just put the magnetic tipped antenna about 1/4in away from the car and all the stuff just jumps right off. rare earth, ceramic whatever it jumps right off the car.
why would i post a solution over and over if it was bs?
Old 04-10-2003, 04:00 PM
Call me Darth Balls
I never said it was.
Old 04-10-2003, 06:53 PM
smokin'1320 smokin'1320 is offline
Send a message via AIM to smokin'1320
speaking of rare earth magnets where do u get them???
carbon fiber, triple deck rear wing : $350.00
"Type R" sticker: $5.00
Stupidity: Priceless
shen qi wei NX
White Xmod supra 6cell Stage2Drift Light Kit awd
Old 04-10-2003, 06:55 PM
xatu's Avatar
I always wondered.... How does that magnet on the antenna thing work anyway?
Old 04-10-2003, 06:57 PM
Call me Darth Balls
UUUmmm. Online store or radioshack
Old 04-10-2003, 06:58 PM
xatu's Avatar
You can get them at www.questformadness.com.
Old 04-10-2003, 10:46 PM
State Property
i was playin with my Gloria earlier and the steerin was backward!..right was left ect....this is the first time this has ever happend 2 me..i had just replaced the steerin spring..what happend ?
Steering problem rody XMODS 1 01-29-2007 10:18 AM
Really Bad Steering Problem, unlike any steering problem before it! 'Vette Nerd ZipZaps SE 11 07-19-2006 10:05 AM
Steering problem Vincent Bit Char-G / MicroSizers 3 11-25-2002 12:11 AM
AH-HA!!! Solved uneven steering problem! mechanist ZipZaps 8 10-17-2002 09:24 PM
