Old 04-10-2003, 08:44 PM
pdcr's Avatar
pdcr pdcr is offline
Go speed racer go!
3.8 prob
I bought a 3.8 and it turned out to be slower than my turbo motor. Can I get some help here?
Gold Honda Civic Zip Zap:
Old 04-10-2003, 08:48 PM
sessiz10's Avatar
sessiz10 sessiz10 is offline
Told ya.
Which 3.8 did you buy?
What car are you using it in?
Is it a newer Zip with a revised board?
It could be a few things down to you getting a bum motor.
____________________
Meh.
Old 04-10-2003, 08:53 PM
pdcr's Avatar
Go speed racer go!
I got the 3.8 from QFM and I'm using the RX8 pcb. I'm planning to switch it out for the automodilissta one. (or however u spell it)
Old 04-10-2003, 09:03 PM
sessiz10's Avatar
Told ya.
The rx8 pcb should be fine with any rpm motor. I don't know first hand which motors qfm sells but I'm pretty sure they're pushing bit style motors (with the small tab contact on the ehdbell of the motor). I had a problem with bit motors not making a good contact in the zips. Most times if you turn the motor in place so the tab is pointing towards the back of the car you'll see a boost. I'm pretty sure it's a contact problem but it could be a bum motor. Have you tried the motor in a bit or clone? What color is the motor?
QFM is here in the states so a refund or replacement should be easy if it's a bum motor.
Meh.
Old 04-10-2003, 09:15 PM
pdcr's Avatar
Go speed racer go!
I used it on my bit and it didnt work...and the back is pink.
Old 04-10-2003, 09:19 PM
sessiz10's Avatar
Told ya.
I had one of those and the thing died within a month. I say return it and ask for an exchange or refund.
Meh.
Will perfection 3.8 and 150 mAH NiMH cell work with my zip zap? Please respond ASAP. ibbored ZipZaps 5 09-11-2003 11:25 AM
I want to give a free 3.8 motor to someone for X-mas bitchar-gmotors Bit Char-G / MicroSizers 10 12-25-2002 03:23 PM
3.2 or 3.8 ZIZI ZipZaps 6 11-26-2002 06:47 PM
2.2 vs. 2.6 vs. 3.8 Namuna Bit Char-G / MicroSizers 14 08-23-2002 09:30 AM
