Old 01-11-2003, 09:17 PM
masterjin
Car for some reason is slowering down?
I dont know why, its not the motor, but my car isnt as speedy as the others. like when pressing forward with another chassis, it goes fast. but when pressing forward with this chassis, it doesnt have that pick up speed as with the other. but top end speed is almost there. its also older then my otheres. no hair in the gears, and motor has NO problem. is the battery getting old or something? its only 1 month old. mm.. i dont know, and i also have a 49mhz to trade for a 45mhz
Old 01-11-2003, 09:18 PM
Superimport2nr Superimport2nr is offline
MASTER PAINTER
Send a message via AIM to Superimport2nr
had that problem too, i had a hair in my FRONT wheels
if not , then just loosen your front wheels a little bit(by pulling the pins out a little more)
the pins might be pushing the wheel in too tight
Old 01-11-2003, 10:06 PM
masterjin
im not getting u man, explain in more detail
Old 01-11-2003, 10:16 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
Try to cycle your motor.
Old 01-11-2003, 10:20 PM
MASTER PAINTER
there is a pin holding the front wheel onto the knuckle.
pull on the wheel so that the pin isnt pushing so hard onto the front wheel
Old 01-11-2003, 10:21 PM
Nathan's Avatar
Bad Driver
And remove any and all hair from those pins.
Old 01-12-2003, 08:50 AM
AudiTF's Avatar
AudiTF AudiTF is offline
Evo VII
Send a message via AIM to AudiTF
Go
If you want a new car battery got to target and buy a kit racer for cheap
________
Ford Gt90 History
Old 01-12-2003, 10:38 AM
masterjin
i think i need a new 27mhz chassis. anyone have?
Old 01-12-2003, 10:39 AM
Nathan's Avatar
Bad Driver
Giving up already? Swap your battery and motor.
Old 01-12-2003, 09:28 PM
masterjin
i also think my motor died. its not causing that effect with slowing down, but i think its burnt. it doesnt go as fast as it used to. anyone have a 3.0?
My Car doesn't work! Eyemfaster XMODS 2 03-02-2005 09:59 PM
Steering Range Fix: Mod the Tierod ikinari XMODS 28 03-31-2004 10:50 AM
Futaba 1/20 Delphi Indy car ksavage68 Other Tiny RCs 3 04-08-2003 07:16 PM
