Old 03-01-2004, 08:10 PM
2fast4u 2fast4u is offline
Send a message via AIM to 2fast4u
toe=lower speed
well i have skied before and i wont lie(i suck) but the begginer stop is shaping your skis like a triangle (pizza as my trainer mentioned) and i found that addidng more cam will push out the back of the wheel possibly slowing it down wen i get and install my awd kist i will test different cam and come back here with results
mini z:ferrari f-40
xmod:body undecided
Old 03-01-2004, 08:27 PM
RC 2NR RC 2NR is offline
TinyRC XModder
Re: cam=lower speed
What are you talking about?
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Old 03-01-2004, 08:51 PM
im sorry i see that i wasnt clearsimply put more cam means that the fron wheels will tilt inward slowing the car down much as a way to stop while skying
mini z:ferrari f-40
xmod:body undecided
Old 03-01-2004, 08:57 PM
TinyRC XModder
I don't know why your calling it "cam", but what you described is called "toe".
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 03-01-2004, 09:12 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
no, he's referring to camber which means the top of the wheel is tilted inward or outward. toe refers to the front of the wheel pointing in or out.
here's an explanation of toe, camber, and caster: http://www.ozebiz.com.au/racetech/theory/align.html btw, the last picture depicting the camber examples at the bottom of the page, when they say (TOP RIGHT), they mean (TOP LEFT) and vice versa
in the xmod, the front wheels exhibit no camber and slight caster. toe is adjusted with the different tie rods. in the rear, because of the simpler suspension design compared to the front, the suspension induces increasing camber as the wheel is pushed up
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 03-01-2004, 09:53 PM
o im sorry then it is toe im talking about that higher toe means more / \ and that slows you down
mini z:ferrari f-40
xmod:body undecided
Old 03-02-2004, 07:11 AM
TinyRC XModder
With that analogy you were talking about camber and toe.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
Old 03-03-2004, 01:13 AM
spinitsidewayz!'s Avatar
boro dori style RC
if ur talking about camber i dont think it would affect speed. and toe... it wouldnt make much of a difference on xmods cause the tierods allow alot of play so they would be able to straighten out when you accelerate. might have an effect on awd?
r34 - rwd
r34 - awd
dd4 - fwd
1/4 mile speed tests Steve ZipZaps 3 02-22-2006 05:16 PM
SE 1/4 mile speed tests Steve ZipZaps SE 8 02-08-2006 02:04 PM
speed speed speed ml22 Bit Char-G / MicroSizers 6 03-14-2003 12:27 AM
