Old 12-20-2003, 09:12 PM
Martlet21 Martlet21 is offline
Send a message via AIM to Martlet21
Arrow Off-Road XMOD with more speed!
Hey guys, I just figured out a great way to make the XMODS run on thick carpet, rocks, almost anything, and have more speed! If you buy the tire upgrade kit, and just overlap the tires on the wheels, the clearance is huge! My clearance is 3/8 inch, and because the wheel is larger, it goes way faster, too.
My setup (from inside to outside) is: hard slick, hard tread, soft tread (inside out for better grip on the hard tread), and soft slick. I couldn't use my stock slicks because they are so worn out.
This does strech ou the tires alot, and I'm not sure they'll ever go back to normal, but I think it's worth it to be able to drive on anything.
Old 12-20-2003, 09:26 PM
AUDI-TT's Avatar
AUDI-TT AUDI-TT is offline
XMOD AUDI TT (my wish)
good idea does it look good too? or is it like weird looking.... and arent the wheels wobbley? (sp?)
Old 12-20-2003, 09:27 PM
Bad Company's Avatar
My question would be if they rub on the wheel wells or chassis when you turn?
Old 12-20-2003, 09:40 PM
The body won't fit on the chassis with the huge tires, but they don't rub on the chassis if I turn the ST. Range down a little. I do get huge grip though, so when I turn sharply, it flips alot. The wheels don't wobble at all, because the momentum of the outside of the wheel keeps it in line. I should get some different rims, though, because stock skylines look horrible with 1/4 inch tires. I'm thinking about getting a Hummer H2 body to put on it, i just saw a good one at Target today.
My Tiny R/C:
XMODS Yellow Skyline GT-R
AWD
Jumbo Tires
Stock everything else
Old 12-20-2003, 09:46 PM
AUDI-TT's Avatar
do it do it do it do it
and dont forget the pics when ur done :-)
Old 12-20-2003, 09:52 PM
Yes, I would like to see this.....DO IT!
Old 12-20-2003, 09:53 PM
I'm getting the body tomorrow, I think I'll paint it maroon, maybe. I'll post pictures as soon as I get a digital camera. I also want to put a light rack on the top or the grille.
My Tiny R/C:
AWD
Jumbo Tires
Old 12-21-2003, 12:50 AM
kasper01001's Avatar
kasper01001 kasper01001 is offline
("\(0.o)/") Rawr!
Send a message via AIM to kasper01001
Do it! Do it! Do it!
Xmod Parts Help
Old 12-21-2003, 08:48 AM
maxximum attack
Can anyone find a way to make any of these???? Instead of monster trucks , SUV's and the like. They look cooler.
Old 12-21-2003, 08:55 AM
maxximum attack
I've seen a model but I have no idea on how to raise my ride height. Martlet21, can you post a pic of your car. I'm thinking
The perfect off-road setup so far:
That tire mod
stock bushings
Skidplate
and maybe a plastic covering for the top of the chassis (between the chassis and the body).
Old 12-21-2003, 11:10 AM
There's no way my tire mod will be able to accommodate a WRX body, because the tires are just too large. It might work if you just overlapped the hard slicks and hard treads, but then you still wouldn't get enough clearance to run off-road. Also, for real off-road, you'd nee to seal up the front and back cavities where the axles are. If real dirt gets in there, you'll need to clean extensively after each run.
My Tiny R/C:
AWD
Jumbo Tires
Old 12-21-2003, 05:54 PM
maxximum attack
That is one of the reasons why i suggested leaving the stock bushings. Light dremmeling can also fix the wheel well problem. Can your mod run on hard packed dirt? No rocks, just compacted dirt.
Plus the ride-height if the body can also be changed. Raised in this case.
I have a WRX body coming, can you post a pic so that I can see what I will have to work with. I cannot do it myself becuz I only have the stock tires. more coming with AWD etc.
Old 12-21-2003, 07:44 PM
aero528's Avatar
aero528 aero528 is offline
like my dog??
i have tires from some other thing that i found around the house, but they are perfect!! you can see them in the pics\/. the body fits but the tires are right up to it. the tires are a little harder, so they do not run so good on wood floor, but they rock one carpet!! well my diff is messed up(also the peice that conects it to the dogbone, any help please!!?) so i can not tell you how fast or what it is, but here are the pics...
--Chris
Aka...aero528
Old 12-21-2003, 07:46 PM
aero528's Avatar
like my dog??
btw the tires did not fit before, but with the stock tires underneith they fit VERY snugley...
--Chris
Aka...aero528
aero528's Avatar
like my dog??
two more...
--Chris
Aka...aero528
Idea-Off road kit on small Xmod? JayVong XMODS Parts and Hop-Ups 1 08-07-2008 01:20 PM
Stock XMOD Speed? m98bigshot XMODS 2 11-06-2004 09:16 AM
Tamiya Speed Checker with Xmod 93Supra0wner XMODS 0 01-05-2004 06:59 PM
