my car doesnt turn fight
ok i did a pcb swap and my car worked then all of assuden my car didnt turn left. i looked under the pcb and all the wires are conected and there conected to the steerin coils. any one know whats up?
the tomy battle chase set is designed to turn fights.
hehe id recheck the steering wires. you got a multimeter? |
is the solder or one of your steering wires touching someting it shouldent one of my wires for steering got hooked into the solder on the pos terminal and my car wouldent turn the other way
Is the PCB black in any spots? If so the problem probably is that you over heated the board!
how do you overheat the board?
its not black in any spots and the wires arnet touching anything else.
id unsolder and resolder the steering wires then.
mabie you didnt take the coating off the steering wire aound where you sodered it
i resoldered it and now it works SWEEEEEET
| All times are GMT -5. The time now is 02:56 AM. |
