-   -   Quick I need to know wheelbase of ZZ... Please? (http://tinyrc.com/forums/showthread.php?t=7598)
dustn 01-29-2003 12:52 AM
Building custom wb bit clone and need to know how long to make wheel base of zipzap or preferably slot car. Thanks.
Fourustwentius 01-29-2003 01:10 AM
You my freind, need a ruler! For $29.95 I will send you your very own!:D
dustn 01-29-2003 01:15 AM
But I dont have a zz... the problem is that i am making a chassis (full-length) and all i have are KIT racers and Bit clones... So I have nothing to go from. I want it to fit lexan slot car bodies. Right now I'm just using the KIT body, extended.
Fourustwentius 01-29-2003 01:17 AM
I've gotta bit char broiled. will that work
dustn 01-29-2003 01:19 AM
mmm sounds yummy but unless its extended, no dice.
Fourustwentius 01-29-2003 01:20 AM
44mm by 27mm
dustn 01-29-2003 01:23 AM
That seems sorta long but then again you drive a hippie bus. My hotwheels MR2 measures 41mm. Thanks for your rapid response btw.
dustn 01-29-2003 11:03 AM
so can anybody measure their zz for me?
Subie Driver 01-29-2003 12:40 PM
4cm long x 2-3/5cm wide
Length is from axle to axle, width is from tire center to tire center, and should be the same as a Bit, since the rear axles are interchangable. Hope this helps.
dustn 01-29-2003 03:55 PM
Thanks. That does help immensely. Now off to make a custom steering setup...
Subie Driver 01-29-2003 07:06 PM
No problem, it was simple request that was simple to answer.
