-   ABC DTM SP (http://tinyrc.com/forums/forumdisplay.php?f=4)
-   -   diff problem (http://tinyrc.com/forums/showthread.php?t=2726)
was ist los? 10-30-2002 08:58 PM
diff problem
im having a hard time keeping my diff tight. how should i fix the problem?
irc 10-30-2002 10:19 PM
try a little blue Loctite on the screw.Let it dry for a while befor running the car at all. I have never tried this so let me know how it worked???
was ist los? 10-31-2002 07:07 PM
thanks for the tip irc. it worked really well, now i can adjust my diff and still have a consistent tightness. before, when i raced on a track, the diff might loosen after a crash or two. now it stays tight. i recommend this tip to every one.
irc 10-31-2002 08:34 PM
Glad to hear it worked. Blue Loctite and myself have been very close latley while putting the aluminum Aktiv car together! you should use it on any aluminum or metal part's on your cars.
was ist los? 10-31-2002 11:12 PM
i should have remembered using loctite, but i have not touched my 1/10 or 1/24 car for a while.
