-   -   Simple hood hinges. (http://tinyrc.com/forums/showthread.php?t=18952)
LBRC 04-01-2004 12:48 AM
Simple hood hinges.
1 Attachment(s)
Easy
1) Trim off about half of the back screw posts on the hood.
2) Glue elastic cord in the holes, you may need to enlarge the holes to fit your elastic.
3) Run the cord through the back screw holes.
4) Tie off the elastic under the body.
5) Straighten and cut a paperclip to length to hold it open.
6) For everyday driving screw the front of the hood down.
LBRC 04-01-2004 12:54 AM
1 Attachment(s)
Underside view.
Joey 04-01-2004 05:53 AM
Well, uh, I guess it's simple alright...
Think it'd work opening the other way? :cool:
LBRC 04-01-2004 01:20 PM
Yes it would.
aperson 04-02-2004 04:40 PM
elastic cord out of a bungee cord? would a rubber band work?
LBRC 04-02-2004 06:52 PM
Yes anything that stretches, fits into the holes, and can be held by the type of glue your using.
The stronger it is the better, and it really helps to let the glue dry all the way before tying it off or pulling on it in any way.
sawhit4 04-02-2004 07:36 PM
but why would you want it to open? i could understand if it had something under there besides a big hole that shows off the grayish brown front chassis suspension but it doesnt. you need to find a model with a plastic engine model and stick it under there.
LBRC 04-03-2004 12:13 PM
1 Attachment(s)
That’s just it there are lots of things you can show.
There are some really cool engraved aluminum front plates. Or how about external FETs. I’m working on a front plate pc board with 2x3 stacked IRF7389’s with some surface mounted diodes to light it up just when you want to show it.
striker289 04-03-2004 12:15 PM
get some plastic mirror matterial to put on the body whre hte hood covers and on the botttom of the hood =P
LBRC 04-03-2004 12:22 PM
RSX Hood
1 Attachment(s)
Like this.
Joey 04-03-2004 05:51 PM
Awesome.
maxvelox03 05-18-2004 12:25 PM
Nice. :D
LBRC 05-18-2004 07:36 PM
1 Attachment(s)
Lights on RSX external fet and regulator front deck pcb show through front opening hood.
LBRC 05-18-2004 07:43 PM
1 Attachment(s)
With hood open.
ninja828 05-21-2004 12:52 PM
:eek: :eek: :eek: WOW....how'd u get tha leds to produce that image under ur hood?
