-   -   what is the most effective way of clearing the lights? (http://tinyrc.com/forums/showthread.php?t=18183)
newbitowner 02-13-2004 12:21 AM
automotive brake cleaner melts the plastic
acetone doesn't take all the paint off
Wedginator 02-13-2004 09:57 AM
here's my experience from plastic model windows. Some times there are scratches on it and sometimes glue accidentally gets on them... so I use very fine grit sandpaper (maybe 1500 grit and wet sanding) and sand it down evenly. In your case, sand it down until u get a smooth feel. Wash the peice in soapy water. U can use turtle wax or floor polish for this step. get a cloth, and in a circular motion buff the plastic. It should get clearer and clearer... since u are polishing a lens, it might be harder cuz it's such a small peice. Don't use a dremel cuz the friction of the buffer will melt the plastic.
theMonster 02-13-2004 11:22 AM
another option
find a cheap toy that's got a thick plastic bubble or buy a cheap lexan body from your LHS, take the tailights out of your car and use them as a stencil to cut the plastic bubble/lexan and use that to replace the red lenses, this way you don't ruin the lenses by accident and can go back to red if you wish.
NissanGTR01 02-15-2004 02:06 PM
if you wanna clear the tails on the civic the paint is on the outside of the lens at least mine was. then you just scratch the paint off gently with a razor knife or similar tool
newbitowner 02-15-2004 02:21 PM
I'm afraid I'd scratch the plastic with a razor. :o
skklown 02-15-2004 05:04 PM
cover up the scratches with clear nail polish
RC 2NR 02-15-2004 08:11 PM
Brake fluid *might* work, but I doubt it. I know it works on spray paint.
newbitowner 02-15-2004 08:37 PM
I found the best thing for XMOD lenses. All you do is soak them and wipe, soak and wipe... This is it...goof-off
You can buy it at most hardware stores. It somes in sprays also. The one I posted is the one I used.
