Full size wheel mod
Hi, I'm thinking about trying the full size wheel mod but wondered how it affected handling. Does handling suffer? Can't find anything on it but if it has already been covered just post me a link, Thanks.:)
after having front rims from a ZZ for a couple of weeks, i have forgotten what the smaller front rims feel like
it does help from high speed spin outs a little |
Next proplem is where to get the rims from. I'll have to have a look around and see what I can find. I'd rather not have to get anything shipped over just for a set of rims.
that just means you gotta buy more stuff...:D
Yep, guess I'll have to get some more bits while I'm at it.:D
Get the ZZ booster set.....get probably 2 packs so u can have the other gears to use. Take off the wheel on the opposite side of the gear on the axle carefully. Do that to 2 axles (that's why u should get 2 packs so u don't end up with only one useable axle) Then trim the little spacer/step on the inside of the wheel so its flush with the outter rim of the wheel. Then mount the tires to BIT KNUCKLES so you have spave when turning. You'll have to modify the bosy some to fit the larger wheels up front, but when your done you'll have a full set of big wheels!!! The great thing about the ZZ wheels is the interchangable hubs and the cool treaded tirez!!! Hope this helps.,
I'd love to but as far as I know theres nowhere to get ZZ's in the UK:(
| All times are GMT -5. The time now is 03:15 PM. |
