-   -   bumped chair..now it doesnt work..at all (http://tinyrc.com/forums/showthread.php?t=12348)
zztop 07-15-2003 11:46 PM
i bumped the leg of my chair during the tour de lanolium..and now i have no movment in my car( rally racer..bit clone), unless i charge it..then i can give it "gas' and steer..untill i rmove it form the charger....any suggestions?
Char-g Ace 07-15-2003 11:50 PM
this happened to me once.
open the pcb cover
slowly pull the pcb up trying not 2 break any wires.
check 4 broken wires
check and see if the battery is in perfectly
Jtskty 07-15-2003 11:51 PM
Yeah, you probably popped out your battery.
nrmcj 07-15-2003 11:56 PM
yep, most likely a shaken battery.
just kinda mess with stuff, not really changing anything, but poking around, move stuff.... usually it helps :)
Jtskty 07-16-2003 12:01 AM
lololololol:D
zztop 07-16-2003 12:29 AM
i did all that
i looked for disconnected wires....made sure battery were touching terminals...i dunno wot else to check
rt450 07-16-2003 01:24 AM
do you have steering but no motor power? if so, the lower motor contact may not be bent up enough or is just moved a little. if you have another car, try switching the batt. also, make sure the motor is making full contact. once you find the problem you'll probably laugh.:D
zztop 07-16-2003 06:14 PM
your right..i laughed
hmmm..wonder if i need to solder these wires back where they belong...(the blue one came off the motor mount)..thnx guys
SkyLiNEz 4-eva! 07-17-2003 05:27 AM
thats probably it, without that wire on the car is of absolutely no use except looking pretty
