bearings
Anybody knows about the bearing's thicknes?
Thank you. :confused: |
which bearing's r u talking about?
Re: bearings
Thank you. |
the 8x12s r ±.137 and which ones r the 3x6s?
The 8x12s are for the diff. bearings and the 3x6s are for the wheels bearings. Correct me if I'm wrong. Thank you. |
same thicknes w/ mtr shaft mount?
Let's make it simple: is the 3x6 wheel bearings have a same thickness with motor shaft mount bearing? Anybody know?
TY |
The 3X6s are either 2.0 or 2.5 mm. I don't remember for sure but I think it is 2.5. They are the same width as the 3X6s in a mini-z.
The 8X12s are probably 3.5mm. Since these are Japanese cars everything is metric. |
Yup, the diameter is the same as mini z wheel bearings, but the center hole is different.
It's hard to get ones here. |
you should get dynamite redseal bearings. i got them all around, the diff and wheel bearrings (10 total). they work better than any bearing i have tried, they never need to be cleaned cause they are teflon sealed and they are pretty :P oh oh and they have a perfect fit too. i got them at my local hobby shop (CycleArt)
You luckily lived at SJ.
In Indonesia it was hard to get one of them.:confused: |
I was actually referring to the mini-z axle bearings. Mini-zs come with 4 wheel bearings - 2X6 and 3 axle bearings - 3X6. The mini-x bearings are the same exact size as the mini-z axle bearings - width, outside, and inside.
YES!
THat was bearings for rear axle at motor pod and one of rear wheel. Thank you very much! |
| All times are GMT -5. The time now is 03:48 PM. |
