looks as if there is a giant booster rocket atached to da chasis of the Zip.
OK... details please:
- is this a modded zz? - where did you get the wheels? - how much? :-) |
if remember corectly they are tires from a f1 slt car or somthing i think
Sorry Steve I am an electrical enginear and I was just giving you the math equation to design the charg and discharg characteristics of a simple RC circit.
:confused: Gruder |
Amazing work Steve; we've promoted this thread to Bit Science!
Good cause I need HELP!
1 Attachment(s)
Ok, after coming so far...I've hit a stumbling block! Unless I'm wrong, I need a relay to switch between one cell and two cell operation. The timer in the turbo module trips the relay, that sends the second battery voltage in series to motor. Releasing the throttle, resets the timer, which causes the relay to fall back to one cell.
HERES THE PROBLEM. The only relay small enough that I could find is 5v. I found that 3volts will actually trip it, but even with two cells, once the voltage drops a little from running, the relay won't work anymore. What I need is either a relay that runs on less than 3v (can't find them), or some kind of other method that I can't figure out. If anyone has any ideas, please let me know. |
i don't know if this is the right realy but i found this
hmmmm
Thanks |
how?
http://www.electronic-kits-and-projects.com/3044.htm
this guy has this kit that you can build, that comes with a 12V relay, but when 1v is applied it triggers....how did he do it!!?? |
So, where do you put the 'Flux Capacitor'...? :D
Nice work! I invent electronic mods and add-ons for real cars, so it's different to see people adding to postage-stamp sized vehicles! Keep up the good work! -Brian |
Re: how?
1 Attachment(s)
dam....nice idea and nice work...too hard for me to even think about:D...u control when u hit the turbo rite?...u also need a BOV(blow off valve ) for that ZZ now:D :D :D
| All times are GMT -5. The time now is 08:02 AM. |
